SanDisk Guru
Tapeworm
0
Re: Sansa Clip Firmware 01.01.35 & 02.01.35 Release
westerdaled wrote:
Hi
am I missing something... I drag m300a (type vlc) file on to my E:\ which is my root folder of my sanDisk Cip 8Gb and disconnect. ...Power off and disconnect ...
Nothing happens...still on v01.02.15p
Oh the downloader just lets me download the latest manual :manmad:
Daniel
See my response 2 posts above yours.
Newbie
westerdaled
0
Tapeworm
Ok,  It was a long short anyway.  I wonder if they will release a firmware update....
Thanks again
Daniel
e
Tapeworm wrote:
You have the latest firmware available for your Clip+ already. The 01.01.35 firmware (1st post in this thread) is for the original Clip (no +) model.
SanDisk Guru
Tapeworm
0
Highly doubtful (in fact I can almost guarantee) there will not be as both the Clip and Clip+ are discontinued now.
What is it you're trying to do and/or solve?
Newbie
yolanda1
0
8gb SanDisk install CDto get started
SanDisk Guru
Miikerman
0
Please speak in full sentences--what are you asking or otherwise saying?
SanDisk Guru
Tapeworm
0
There is no installation CD. Some of the older players came with a mini-CD, but all that was on it was a copy of the User's Guide (which you can get here on the forum) and a free trial to Rhapsody pay-to-play music service.
Neither of which you need to use the player (although I would recommend reading the manual).
Newbie
littlebigman
0
[ Edited ]
Hello
After upgrading my Clip+ from 01.02.16A to 01.02.18A through the SansaUpdaterInstall.exe installer, I followed the instructions to upgrade manually to 01.01.35, but it didn't work: After copying m300a.bin to the root of the device and disconnecting it from the XP host, the device didn't reboot. Hard-rebooting made not difference: It doesn't upgrade, and it's still running 01.02.18A.
Does someone know how to upgrade to 01.01.35? Should I try RockBox instead?
Thank you.
SanDisk Guru
Tapeworm
0
littlebigman wrote:
Hello
That's because you're trying to install firmware for the original Clip (01.01.35) on a Clip+. They are 2 different players and the firmware is not interchangeable.
01.02.18 is the latest for your model, so you're good to go. :smileyhappy:
