Newbie
Replacing the battery on my Sansa Clip + - Help Needed
Hi Guys
I've got two Sansa Clip + models that I'm desperate to replace the batteries on before I go on holiday next month.
I've stripped them down ready, each one has 3 wires and a mini circuit board attached to the battery, both batteries are completely dead and I mean they won't even power on, however I know they both work before being stored.
Ok So I've heard lots of stories about using diffrent ipod batteries and so on.
Question is what can I use for certain without too much modding and where can I buy from?
I'm in the UK
Cheers
Pete
SanDisk Guru
Re: Replacing the battery on my Sansa Clip + - Help Needed
Check the anythingbutipod forum. I believe some guys there have done it sucessfully and have posted photos & a guide to do it.
