turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
No sound from sansa clip+Options
02-21-2012 05:47 AM I have a 5 month old sansa clip+ that has stopped giving out any sound. The screen says it's working, has all the normal display but no sound, have tried several earphones and stereo speakers. Looking at the headphone hole there is evidence of slight damage, ie where the baby may have tried inserting the headphones too forceably at the wrong angle. Is this likely to have damaged the inside? Anything I could do to it? as I assume the warranty would be invalid. Thanks Re: No sound from sansa clip+Options
02-21-2012 08:41 AM Are you sure it's just not on PAUSE ? Re: No sound from sansa clip+Options
02-22-2012 03:32 AM Definately not on pause, however have realised it's not that there is NO sound it's just very low, so some tracks that are quite low volume played on anything now have no sound, other tracks play much quieter than before. The volume is set to 'rest of the world' but the tracks have always been audible previously. Re: No sound from sansa clip+Options
02-22-2012 07:40 AM Is the Volume option set to HIGH in Settings? Re: No sound from sansa clip+Options
02-22-2012 12:06 PM Yes, the volume has always been fine previously. Re: No sound from sansa clip+Options
02-22-2012 05:03 PM If you haven't yet done it, try a reset of the player (hold the on button down for 30 seconds or more). Also, try a reapplication of the firmware (the code can become corrupted)--see the firmware upgrade sticky thread at the top of the forum. Re: No sound from sansa clip+Options
02-23-2012 03:20 AM thanks, I'll try them. Re: No sound from sansa clip+Options
02-23-2012 04:20 AM OK, I've updated the firmware and tried the reset. I have two other clip + (1 for me, 2 for the kids) - Comparing them, the volume on the affected one at max is about what it is at half volume on the other two. Re: No sound from sansa clip+Options
02-23-2012 08:19 AM
But you didn't answer my question . . .
There is a Volume option in the Settings menu for either NORMAL or HIGH. Check to see that it is set to HIGH. Re: No sound from sansa clip+Options
02-23-2012 10:20 AM Sorry, I wasn't clear. Yes it is. |
