Sansa Clip+ 4 Gigabyte
MTP mode
32GB MicroSDHC
Windows 7 64-bit Winamp(no additional plugins)
I recently bought a new 4GB Sansa Clip+ with a 32GB MicroSD card. Using Winamp, I synced my library to the SD card. Everything went as expected, no problems to report, I could play every song perfectly.
But now, whenever I try to sync the player’s SD card, Winamp doesn’t seem to recognize the files that it had previously synced. A window tells me that there are X number of songs on the Sansa Clip+ that aren’t in the library, and prompts me to delete them, leave them, or cancel.(pic of the window below)
Basically, Winamp is telling me over and over to delete and re-sync a load of songs that are already on the player, which is extremely time-consuming and tedious when all I want is to sync an album or two. This happens even if I plug the device out, let it refresh, and plug it back in to sync again.
If anyone had this same problem and would be willing to share the solution, it would do me a huge favor. Thank you.
