Newbie
Accepted Solution
How to disable FM radio?
I have a Clip 8gb with V02.01.32p firmware.
I need to use my clip in a place where FM radios are not allowed, and I never use this feature anyway.
How can I disable the FM radio feature?
SanDisk Guru
Re: How to disable FM radio?
http://www.anythingbutipod.com/forum/showthread.php?t=45533
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Newbie
That worked. Thanks!
SanDisk Guru
Wouldn't it be a bit more polite to mark Marvin's post as the accepted solution, instead of giving yourself credit?Smiley Wink
"Before I sink into the big sleep...I want to hear the scream of the Butterfly"
Newbie
Sorry, I'm new at this.
Fixed.
SanDisk Guru
Fixed.
No problem...
Newbie
how can i disable the fm radio on a sansa clip?
SanDisk Guru
If you reapply the latest firmware (see the firmware upgrade sticky thread in the forum, at the top) and change the .bin firmware file name that you apply to a non-radio version, that should disable your radio.  See the thread below for the firmware file name to change to--seemingly, the "S" option will fit your needs.
http://www.anythingbutipod.com/forum/showthread.php?t=25408
