Newbie
How do you know when battery is fully charged?
How do you know when battery is fully charged on my Clip & Clip +?
I don't want to OVERCHARGE
Rick4q
SanDisk Guru
Re: How do you know when battery is fully charged?
You won't overcharge:  the Clips have an overcharge protection circuit.
But you can check the amount of the charge left by looking at the Clip's battery icon on the display:  if it is full, 2/3rds full, 1/2 full, etc.  You can also look under the Info screen (under the settings) to see the amount of battery charge left.
Newbie
Thanks for the correct information.
This is the reply I received from a SanDisk Tech Rep.
Thanks for emailing SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
I understand that you don't want to over charge the battery of your sansa players. I would like to inform you that when the battery is fully charged it will show you a message "charge complete".
I knew he was wrong because I have been charging 36 Hours & no "Charge Complete" message yet.
Thanks Rick 4q
SanDisk Senior User
Continuously charging for 36 hours?  Yeah, there's no message, just the battery animation stops when it's charged.  Unplug and check Settings> System settings > Info and scroll down to see the % battery charge.
SanDisk Guru
Thanks Rick 4q
1.) The "Support" person obviously needs to go through some more training. There is no (nor never has been) a "Charge Complete" message.
2. 36 hours?   :smileysurprised:    It only takes 3-4 hours MAX for a full charge. Many times even less.
Newbie
Thanks everyone,
I was wondering the same thing.
The little icon that comes up on the bottom of screen when the sansa clip+ is plugged in to computer says power is "extremly low (0%), and it says the same thng in the Sansa updater window.
I followed your instructions and checked the info screen of the the Sansa unit itself, and it shows 100%.
duh! to Sandisk.
Thanks to all who contributed.
I think WE THE PEOPLE would be lost if we left it up to the manufactuers. We need each other.
Live long and prosper.
danny
ASUS Rampage lll Extreme: Intel i7 930: 6GB Corsair RAM: MSI N470GTX Video: OCZ Vertec lll SSD
