After having some addressing problems I ended up trying to reformat. The machine has now completely frozen and not recognised as a device by my computer.
Did you format from the unit? (Settings/System Settings/Format)?
DId you format from Windows?
DId you format from Mac?
You need to explain more clearly.
I fortmatted from the unit.
I later tried holding on/off for some time (30) secs plus.
Success - the unit switched off.
Subsequently turned on again as if nothing had ever happened - complete with data!!
I thought a format would erase all data??
Thanks for replying.
I am interfacing via Windows XP and have recently installed a 32g class 4 card
Formatting using the menu on the Clip+ formats the internal memory but does not affect the card.
If you still have all your music, etc. then the Format didn’t take. Pressing the power button for 30 secs. performs a reset.
