My clip keeps freezing. After reading this forumn I decided to format the player. I backed up my files from the internal memory, removed my SD card, and reformatted. I also had problems with the folders on my micro SD card so I switched the player’s usb modes from MTP to MSC. I insterted my SD card and turned it on and it’s not showing the SD card. Is there a way to get it to show up again in MSC?
Thanks.
