Hi, When i charge my Sansa Clip 2GB i see the “Connected” screen, but every few seconds the screen says “SanDisk” and then goes back to the charging (connected) screen. Is it normal? Or does it supposed to stay on the “Connected” screen all the time?
I just bought a Sansa Clip and understand that the screen will go back and forth from screen saver to showing that it is charging. What I am wondering is if the flashing yellow bar will ever get solid to show that it is fully charged or will the screen at least say charged? How do you know when it is done charging?
Thanks so much for any help!
Heidi
It will stop flashing and be completely full when it’s charged all the way:smiley:
I am unable to charge my Ipod using my laptop computer with UBS cable. Message states battery is low. When the IPOD is connected to laptop the screen shows connected - but not charging. How do I start the charging process. I have left it connected for over 2 or 3 hours with no result in charging the battery.
