turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
Charging Voltage for Clip+Options
03-01-2011 06:23 AM Anyone know the maximum permissible DC charging voltage that can be applied to Clip+ without frying it? I'm wondering if I can use the car cable from my (Garmin) GPS which has the same usb connector and supplies 5-8 volts DC.
0
Re: Charging Voltage for Clip+Options
03-01-2011 08:21 AM 5.5v is as far as I would go.
0
03-01-2011 12:11 PM The Clip spec is for 5V.
0
02-10-2012 08:32 AM Just some information for you all.
The Kindle charger that has the detachable USB cord works fine with the clip. It's 4.9v.
Also, the charger that comes with the T Mobile MyTouch 4G phone and has the detachable charger works. It's 5.0v.
All you have to do is put the standard mini-USB cord that comes with the Clip into either the Kindle or MyTouch charger and away you go.
0
02-12-2012 10:50 PM I have a USB charger for the LG Octane that runs at 5.1 v out. Will that work?
0
02-12-2012 11:10 PM
Anything between 4.9V and 5.1V should be fine. The USB spec is 5.0V. You might be okay with slightly more or less, but IMO it's not worth the risk.
