Newbie
4GB Sansa Clip+ frozen, won't reset, computer doesn't recognize it
I was listening to it and it just froze. I did what I normally do when this happens and held the power button down for 15-20 seconds, but it didn't work this time. Now my computer doesn't even recognize it. What do I do?
SanDisk Guru
Re: 4GB Sansa Clip+ frozen, won't reset, computer doesn't recognize it
Hold the power button longer.
Newbie
Held it 5 minutes.....nothing
SanDisk Guru
[ Edited ]
Well, if it's still on just wait for the battery to run down. While this sounds too simple to really do anything, many have reported that it indeed does work. Once the battery is completely depleted, you can plug it in and it will recharge, then operate normally.
It may not work 100% of the time, but you don't have a lot of other options to pick from at this point. If you still have problems, you should call SanDisk Tech Support. If it's under warranty, you may get a new one out of it.
Newbie
Same thing happened to me and I just received it as a bday gift a few days ago.
There is a small pin hole on the back of it, just above the clip, I put a pin in it and it just restarted.
Hope this helps!
SanDisk Guru
[ Edited ]
Hope this helps!
Really? I've never noticed this. But then, I've never had any problems with any of my Sansa players I couldn't resolve through other means.
Edit: Thanks to priell217 for pointing out this little hole is NOT a hard reset button as one will sometimes find on other electronic devices, but rather the microphone opening.
Newbie
[ Edited ]
Hope this helps!
That's cool and very good to know, that there is a 'hard reset' available via a hidden 'button' on the back. I'm going to bookmark this post for future use.
Good find!
That hole is the microphone!
SanDisk Professor
Hope this helps!
Dont try that again, It might damage the microphone of the Sansa. Smiley Wink
SanDisk Guru
priell217 wrote:
Hope this helps!
Good find!
Noted. Beings I'm at work (ssshhhh, don't tell the boss) and didn't have my Clip+ with me, I didn't have the chance yet to check it out.
Thanks . . . removed the bookmark. Smiley Wink
Newbie
you've probably figured it out by now...I locked mine....then hold down the power til it resets.......
