Newbie
What is the difference between microsd and microsdhd?
What, exactly, is the difference between a microsd card and a microsdhd card?  Is a microsdhd card compatible with a microsd device?
SanDisk Guru
Re: What is the difference between microsd and microsdhd?
It's microsd and microsdhc...and the difference is the microsdhc cards have more capacity. Smiley Happy
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Senior User
[ Edited ]
MicroSD cards can only hold up to 2GB.  MicroSDHC (HC means "High Capacity" ) range from 4GB to 16GB currently, with the possibility of 32GB.  A microSDHC card uses a different protocol to transfer the data, so a device built for microSD cards may or may not read it; it depends on the device.  The hardware controller is different, but some newer devices can be updated to newer firmware to read them.  Again, it all depends on the device.
Wikipedia has a page on SD cards in general that has a section on the SDHC types:  http://en.wikipedia.org/wiki/MicroSDHC#SDHC
Message Edited by jkj1962 on 05-06-2009 05:29 PM
