Newbie
Glitch in iXpand 4.2.1 / Reliable method for backups
While doing my monthly backup on my iPhone SE (10.2) I noticed one of my photos had a glitch in it.. i.e. it had repeated bottom lines in the JPG.
I did a search for "reliable" and "glitch" seperately and came up with zilch.
Does anyone know how reliable this software/hardware is?
I've always trusted SanDisk, but after a corrupted SD card and now this gltch I'm not so sure anymore.
iPhone SE (6)
iOS 10.2
iXpand 64 GB (for iPhone duh)
iXpand Drive v4.2.1
Thanks
SanDisk Guru
Re: Glitch in iXpand 4.2.1 / Reliable method for backups
you mention that you noticed this after your monthly backup. Do you still ahve the original file? If so you can check the source file and see if the source file has the same issue. If so the source file is the issue. if not you can delete the corrupted file and restore the original.
If you no longer have the source file this is not technically a backup. a backup is only a backup if there is more than one copy of the file. if you are using the iXpand to free space on your phone and then deleting the source files you should be backup up the ixpand to a computer. If you are not doing this you do not have a backup you only have the files.
data corruption can occur during capture, during transfer, or during storage and can occur for dozens of reasons. Data corruption is not necessarily a problem with the storage device. This is one of the many reasons why having more than one copy of data is important.
