turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
![]() Failed to connect to iXpand Drive iPhone 7 and iPad Air 1,iOS 11Options
09-21-2017 02:32 AM Hello
I have iPhone 7 and iPad Air 1 OS is iOS 11 After install apps the devices show message "Failed to connect to iXpand Drive. Please remove and reattach." I try remove and reattach but has the same error.
But it's work on iPad Air 2 iOS 11.
Please help. Solved! Go to Solution. ![]() Re: Failed to connect to iXpand Drive iPhone 7 and iPad Air 1,iOS 11Options
09-21-2017 08:15 AM Have you reset the iPhone 7? There are two know issues with iOS 11. These are not isolated to the iXpand product and affect all devices from all manufacturers in this product class. We have opened a ticket with Apple regarding both if these issues.
1. In iOS 11 it may take up to 30 seconds for the iXpand to be recognized by the iOS 11 device. this issue is somewhat intermittent in nature but may occur up to 50% of connections. The work around is to wait 30 seconds after connecting the iXPand Drive to an iOS 11 device.
2. Drives will not be detected are after an iOS 11 device has been reset. the work around for this issue is do not reset the iOS 11 device after updating to iOS 11.
If you have reset the iPhone 7 and are now facing this issue you may need to downgrade to iOS 10.3.3 test the iXpand device to ensure it is working then perform the upgrade to iOS 11 again and ensure the iOS device is not reset after upgrading to iOS 11. Re: Failed to connect to iXpand Drive iPhone 7 and iPad Air 1,iOS 11Options
09-21-2017 08:29 AM Hello slotmonsta
My iPhone 7 reset after upgrade. In my case iPhone 7 (iOS 11+Reset after upgrade) can detect iXpand but can't connect.
Thank you
09-21-2017 08:33 AM you may be able to downgrade to iOS 10.3.3 and then re-upgrade. See instructions below.
http://www.macworld.co.uk/how-to/apple/how-downgrade-from-ios-11-3664217/ Re: Failed to connect to iXpand Drive iPhone 7 and iPad Air 1,iOS 11Options
09-21-2017 08:45 AM
Thank you drlucky.
11-05-2017 10:19 AM Hi,
I have a similar issue, but the suggested solution will no longer work for me as Apple already stopped signing iOS 10.3.3 therefore downgrade is no longer possible. Any other possible workaround for this issue? I'm hoping you could help me. Thank you.
11-29-2017 06:50 PM badly needed solution for reset iPhone 7+ on iOS 11.1.2 Re: Failed to connect to iXpand Drive iPhone 7 and iPad Air 1,iOS 11Options
11-30-2017 08:15 AM that is an iOS issue. from what i have read on some other forums the issue is resolved in the iOS 11.2 beta. |
