Newbie
Accepted Solution
ixpand usb 3 32gb does not show in disk utility in macOS 10.13
I bought a ixpand usb 3 32gb yesterday and would like to format it to exfat on my mac. It shows as a device and I can add films and erase objekts on it, but when I open disk utility it is not there.
SanDisk Guru
Re: ixpand usb 3 32gb does not show in disk utility in macOS 10.13
in 10.3 under disk utility in the upper left corner there is a new button "View" click that button and select "View all devices" and you should see the ixpand.
