Newbie
tinkukamsena
0
pasward problem
i hav a sandisk 4gb memory card. but now the card doesnot accept the pasward. how can i unlock my micro sd memory card. pls hep me.
SanDisk User
nayan007
0
Re: pasward problem
Some times it happens that you forgot the password of your memory card (MMC, micro SD) and you have lots of your important data in it. and You struggle to get back your password. Right? Today am going to show you how you can recover the lost password of your memory card with the help of nokia phone.
It is possible only if you have Nokia’s s60 phone (eg: 6600, 6610, N70,N73,E63,E71,N95)
The thing you got to do is download and install “Fileexplorer” software.
After installing follow the steps:
1. Open FExplorer and access the c: drive.
2. There u will find a file named ‘mmcstore’
3. Rename the file to: ‘mmcstore.txt’
4. The file will now open in notepad
5. U will get your password written in the notepad file
____________________________
- Nayan007
Newbie
lodhig
0
Re: pasward problem
use the file explorer for the password restoring
[IMG]http://imagicon.info/cat/5-43/dontknow.gif[/IMG]
Newbie
mukesh
0
Re: pasward problem
my sandisk memory card pasword by lost
VIP
gls
0
Re: pasward problem
Press and hold on a file and you will have options to pick the "hint question" that you defined when you set the password.
Newbie
pollostar
0
Re: pasward problem
[ Edited ]
Its not tough to unlock card it is a simple procedure
So follow my steps:
Insert the card into computer and click on SD card and copy the MMSCTORE file and paste anywhere in computer that means you have edit access.
Right click on SD card and go to open with and open the file in  word and here your password in text form and now you can read your password and can unlock your card.
______________
http://technical-support.igennie.co.uk]Technical
http://www.igennie.co.uk/hp-support.html]HP
SanDisk Guru
drlucky
0
Re: pasward problem
So follow my steps:
______________
Not an issue, What you see in the file using MS Word is the password in encrypted form, NOT in the clear!
Newbie
jyothijo
0
Re: pasward problem
i forget my memory card password
SanDisk Guru
Tapeworm
0
Re: pasward problem
Did you read any of the posts in this thread before you posted? In particular, this one?
