Sandisk Extreme 120 not recognized by bios
I have a
Gigabyte X58A-UD3R Motherboard.  The SSD is plugged into the white port (even tried the blue).  My bios is not recognizing, nor is windows 7.  My motherboard supports Sata 3.  I have tried it in IDE and AHCI in the bios…
Anyone have a similiar problem
if it is not recognized in the BIOS it is likely bad. not really anything you can do. it will need to be replaced.
That’s just tough luck. I assume that you still have warranty on this right? <img src=“https://imagicon.info/cat/5-43/16x16\_smiley-happy.gif”/>
the ssd has a 3 year warranty so you should be good to go. contact sandisk suport.
Try unplugging and replugging it. It could only be just a loose connecting. At least hopefully.
