Hi guys :
I dont se de disk un my power mac, i can upgrade or degrade the firmware ? what you tink
I check my system overview and serial show ST31500341as
Hi guys :
there is no R311 for this ssd latest FW is R211.
the serial number you show is not a sandisk ssd serial number. are you sure you are looking at the correct drive?
if the SSD is not detected you will not be able to update the FW.
