Administrator
SanDisk Extreme Pro® SSD
Play games? Make games? It’s time to get Extreme
Game without limits when you step up to the 24/7 high-performance nCache™ Pro Technology delivers. Graphics-intensive games load in a heartbeat and run blazing fast to keep you immersed in the action.
  • Innovative nCache™ Pro technology delivers consistent high performance
  • Pro-level read and write speeds
  • Load and run games and graphics-intensive applications blazing fast
  • Industry-leading 10 year limited warranty**
  • Easy-to-use SSD Dashboard for drive monitoring and management
  • Cool, quiet operation and low power consumption
Why SanDisk Extreme PRO SSD?
It’s simple. No stall. No stutter. No crash and burn. Just speed.
Extreme Performance
  • Consistent performance you can count on
  • Low latency
Extreme Reliability
  • Engineered to optimize drive endurance
  • Huge storage capacities
  • SSD Dashboard reports drive status
Environmental Soundness
  • Cool, quiet, energy-efficient operation, with no moving parts
  • Lower power consumption
  • Up to 33% longer laptop life
What does sustainable high performance mean?
The performance numbers SanDisk makes public reflect the speed SanDisk Extreme PRO® SSD maintains over time with sustained heavy use, not the peak it achieved for only a few seconds. This translates into years of lightning fast gaming and multimedia.
Tech Stuff
Because you like to know what’s under the hood, here’s how we make SanDisk Extreme PRO SSD deliver an exceptional gaming experience.
  • Innovative nCache™ Pro technology delivers sustainable high performance 24 x 7 x 365
  • Over-provisioning and over-clocking offer faster performance and long term endurance
  • SanDisk’s proprietary tiered caching across three storage layers optimizes write performance and responsiveness
  • SanDisk SATA SSDs are built with the highest quality NAND memory
  • TRIM support and Background Garbage Collection constantly free up unallocated blocks that once held data to lower latency and boost performance
  • Thermal throttling protects critical drive components against extreme high temperatures to ensure data integrity
  • SanDisk SSD Dashboard includes S.M.A.R.T. support to monitor the health of your SSD in real time to prevent data loss
  • Available capacities: 240GB, 480GB and 960GB**
  • Dimensions: 2.75 x 3.96 x 0.28 in. (69.85mm x 100.5mm x 7.0 mm)
  • Operating temperature: 32ºF to 158ºF (0ºC to 70 ºC)
  • Storage temperature: -67ºF to 185ºF (-55ºC to 85ºC)
  • Interface: SATA Revision 3.0 (6 Gb/s)
  • Shock: Resistant up to 1500 G @ 0.5 m/sec
  • Vibration (Operating/Non-operating) : 5 gRMS, 10-2000 HZ / 4.9 gRMS, 7-800 HZ
  • Power Consumption (active): 0.13w (240 GB), 0.15w (480 GB, 960 GB)
  • Support: 10 year limited warranty**
  240GB480GB960GB
Performance** Seq. Read (up to) 550 MB/s 550 MB/s 550 MB/s
  Seq. Write (up to) 520 MB/s 515 MB/s 515 MB/s
  Rnd. Read (up to) 100K IOPS 100K IOPS 100K IOPS
  Rnd. Write (up to) 90K IOPS 90K IOPS 90K IOPS
Product Numbers
SanDisk Extreme PRO Solid State Drive
Americas/Asia-Pacific/Latin America/Middle East and Africa
China
SDSSDXPS-240G-G25 – 240GB SDSSDXPS-240G-Z25 – 240GB
SDSSDXPS-480G-G25 – 480GB SDSSDXPS-480G-Z25 – 480GB
SDSSDXPS-960G-G25 – 960GB SDSSDXPS-960G-Z25 – 960GB
Australia
SDSSDXPS-240G-Q25 – 240GB
SDSSDXPS-480G-Q25 – 480GB
SDSSDXPS-960G-Q25 – 960GB
Newbie
Re: SanDisk Extreme Pro® SSD
[ Edited ]
Well when i bench my SSD Extreme Pro i never see more than 395MB/s Write & Read whats up with that ?
+ The SanDisk Dashbord always crashes will there be a fix i meen like i cant have it running in the background when fx gaming to see reads n writes.
SanDisk Guru
there could be many different reasons why you are not seeing the fill speed, SATA chipset, SATA driver, disk not aligned etc. Contact sandisk support and they should be able to help you sort it out.
SanDisk User
If we knew what mother board you were using, we could then determine if it is the limiting factor, which it is most of the time.
Saying you never see more than 395MB/s read and write speeds is almost worthless without telling us what benchmark or other measure of IO speed you used.
Newbie
[ Edited ]
You can sort the data. : cattongue:
