Administrator
Firmware update X21200RL released for SanDisk Extreme Pro SSD
[ Edited ]
Firmware version X21200RL has been released for SSD Extreme Pro SSD.
Firmware Upgrade installation: Download and install the SanDisk SSD Dashboard and update the SSD FW via the Tools > Firmware update Tab
Windows
Download SanDisk SSD Dashboard
Windows / Mac / Linux
Manual FW upgrade ISO download
Mac
FW update instructions
Release notes:
SanDisk Extreme PRO SSD (240GB, 480GB & 960G): version X21200RL (release date: Jan 23, 2015)
New changes since version X21100RL:
- Improved DEVSLP compatibility.
- Improved compatibility with certain systems where SATA link sometimes negotiated to SATA 2 vs SATA 3.
- Added periodic save SMART Attribute to non-volatile memory
Known issues:
- None
Note: If you already have the SSD Dashboard installed, then please update to the latest version of the SSD Dashboard application before performing the firmware update for the Extreme Pro SSD. You do not have to uninstall the previous version of the SSD Dashboard; the latest version will replace the previous version.
Newbie
Re: Firmware update X21200RL released for SanDisk Extreme Pro SSD
[ Edited ]
Hello! And what changes in X21100RL?  Nothing to compare with.
Newbie
I get "This operation failed with error code: 10" when I try to update.
What should I do?
SanDisk Guru
What should I do?
are you using the in windows update or are you creating a bootable USB or CD? If you are getting the error in windows update click more options below the FW update message and create a bootable USB drive and see if you can use that to update the FW.
SanDisk Guru
X21100RL was the original shipping FW. SanDisk does not have release notes for the original shipping FW.
Newbie
[ Edited ]
I have this drive with firmware x21000RL. The original firmware for SanDisk Extreme Pro SSD is x21000RL.
And I want to know what has changed in the firmware x21100RL.
Newbie
Where can I down load X2100rl?
I have installed SSD Dashboard 1.3
I hope the update fixes the trouble I am having with the drive.
It loses Microsoft Boot Manager each time I remove the Plug in drive cage from my computer.. Yes... it is powered down when I do it.
SanDisk Guru
according to the post X21200RL is currently only available via the SSD dashboard. If you have the dashboard installed go to the Tools > Firmware update tab and you can install it there or create a bootable USB drive and update the FW using that.
Anonymous
[ Edited ]
In the new firmware i get Error: 0x80070057 at win 8.1 setup program "unable to format partition".
(Previous actions, erasing disc using sandisk ss dashboard bootable media).
Laptop: Acer M5-581TG
Newbie
hi,
is this in response to the compatibility issue with intel controllers?
