Newbie
Bad blocks (and kernel panic) with SanDisk Extreme Pro 480GB.
[ Edited ]
I started using  SanDisk Extreme Pro 480GB recently on a laptop with Debian testing (Linux).
It started working OK, but already a couple of time for the past few days I experienced system hanging / kernel panic messages, with system reporing that filesystem (XFS) fails to write.
That's what smartctl -a reports:
smartctl 6.5 2016-01-24 r4214 [x86_64-linux-4.5.0-2-amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Marvell based SanDisk SSDs
Device Model:     SanDisk SDSSDXPS480G
Serial Number:    ######
LU WWN Device Id: ######
Firmware Version: X21200RL
User Capacity:    480,103,981,056 bytes [480 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Jun  7 18:13:48 2016 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (    0) seconds.
capabilities:                    (0x11) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        Suspend Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  10) minutes.
SMART Attributes Data Structure revision number: 4
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   ---    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   014   100   ---    Old_age   Always       -       14
 12 Power_Cycle_Count       0x0032   100   100   ---    Old_age   Always       -       46
166 Min_W/E_Cycle           0x0032   100   100   ---    Old_age   Always       -       0
167 Min_Bad_Block/Die       0x0032   100   100   ---    Old_age   Always       -       46
168 Maximum_Erase_Cycle     0x0032   100   100   ---    Old_age   Always       -       2
169 Total_Bad_Block         0x0032   100   100   ---    Old_age   Always       -       935
171 Program_Fail_Count      0x0032   100   100   ---    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   ---    Old_age   Always       -       0
173 Avg_Write/Erase_Count   0x0032   100   100   ---    Old_age   Always       -       0
174 Unexpect_Power_Loss_Ct  0x0032   100   100   ---    Old_age   Always       -       7
184 End-to-End_Error        0x0032   100   100   ---    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   ---    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   ---    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   059   043   ---    Old_age   Always       -       41 (Min/Max 25/43)
199 SATA_CRC_Error          0x0032   100   100   ---    Old_age   Always       -       0
212 SATA_PHY_Error          0x0032   100   100   ---    Old_age   Always       -       0
230 Perc_Write/Erase_Count  0x0032   100   100   ---    Old_age   Always       -       0
232 Perc_Avail_Resrvd_Space 0x0033   100   100   004    Pre-fail  Always       -       100
233 Total_NAND_Writes_GiB   0x0032   100   100   ---    Old_age   Always       -       40
241 Total_Writes_GiB        0x0030   253   253   ---    Old_age   Offline      -       17
242 Total_Reads_GiB         0x0030   253   253   ---    Old_age   Offline      -       11
244 Thermal_Throttle        0x0032   000   100   ---    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
You can notice that it shows 935 bad blocks already. Is that normal, or SSD is faulty?
Also, temperature is shown as 41. Is that rather high? The laptop had original drive (HDD) wrapped in a foil cover. When I replaced it with SSD, I wasn't sure whether foil was needed, so I just transferred it on to SSD. May be it's not a good idea heating wise?
Thanks!
Newbie
Re: Bad blocks (and kernel panic) with SanDisk Extreme Pro 480GB.
[ Edited ]
Hm, I found this which sounds very suspicous: http://www.thinkwiki.org/wiki/Category:W540
Activating the NVIDIA GPU causes memory corruption leading to crashes and file system corruption. https://github.com/Bumblebee-Project/bbswitch/issues/78
VIP
Hi Shmerl,
I don't have much experience on the Debian, but for the drive bad blocks reporting, since you have a 480G drive, I wouldn't be too worried unless we see a rapid increase in bad block counts, in another word, this is still within acceptable range.
For the temp of the drive, it is within spec and you should not worry about it, if you run a lot of write on the drive the temp will raise a little bit, but I don't see any problem with it.
