Newbie
Accepted Solution
System Compatibility
Is the series compatible with Linux?
SanDisk Professor
Re: System Compatibility
as far as i know its detected as a normal external hard drive so i do not see a reason why its not compatible.
Good Luck
#Missing the keyboard? Press F1 for help#
Newbie
Thanks Smiley Happy
SanDisk Professor
You are very welcome!!
Good Luck
