Newbie
Sandisk Extreme 900
Recently I bought a sandisk extreme 900.
I was using the samsung T5 as of now. There once the password is given the protected area of the disk is shown as as seperate drive. And all programs can access as say E:\. From dosprompt also you can refer it as E:\
As i see the sandisk since everything is inside the vault, you can directly refer to the as a drive
Can some one help me on this
Thanks
Jose
Newbie
Re: Sandisk Extreme 900
Basically after giving the password, my programs want to read the data with the path as E:\Data\...
Is this possible?
Regards
Jose
SanDisk Guru
The secure access software is not a full drive password protection. It is a password and encryption application. Other applications would not have access to data stored in the secure access vault. You would need to decrypt the files and put them on the drive  (not in the SA application) before other programs could access the files.
Newbie
If I do that i dont get the protection feature. I need both combined as its available in Samsung T5, Possible?
Regards
Jose
SanDisk Guru
you may be able to find some third party app but the app from sandisk will not do what you need.
Newbie
Any idea whether the Samsung app will work on this?
Regards
Jose
SanDisk Guru
you can try but i doubt it. typically software provided by a manufacturer will be locked to their products.
