Newbie
Accepted Solution
turn on wireless on pc connect and move from drive
can the wireless stick tun on wireless once it's pluged in and turn it off once it's disconected
also as I understand you can use it as a backup device, but can you set up to offload everything off the drive to an andoid phone?
SanDisk Guru
Re: turn on wireless on pc connect and move from drive
if the drive is connected to a PC it is mounted as a MSC (Mass Storage Class) device. When it is mounted as a MSC devcie the WiFi is disabled.
You can connect it to an AC charger and wifi will still work.
