Newbie
cannot browse to the stick
It connects ok:-
SSID: SanDisk Connect F02DF5
Protocol: 802.11n
Security type: WPA2-Personal
Network band: 2.4 GHz
Network channel: 8
IPv4 address: 192.168.0.8
IPv4 DNS servers: 192.168.0.1
Manufacturer: Marvell Semiconductor, Inc.
Description: Marvell AVASTAR Wireless-AC Network Controller
Driver version: 15.68.9112.23
Physical address (MAC): 4C-0B-BE-16-CE-BE
I can ping it:-
C:\Users\mIphone>ping 192.168.0.8
Pinging 192.168.0.8 with 32 bytes of data:
Reply from 192.168.0.8: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.0.8:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
But I cannot browse to it, either using the ip address, or the
or
Any ideas?
Thanks
SanDisk Guru
Re: cannot browse to the stick
do you have internet access on the computer? If so the link you are using will not work. It will resolve to the not connected page on the sandisk website.
