Newbie
Using the stick with a projector
I purchased the wireless stick to use it with a projector. But the projector does not recognize the stick.
The projector does recognize "normal" usb sticks, but when i put the wireless stick in, it says "no device".
The light of the stick turns on when i put it in, so i think its chraging its battery instead of sharing images.
Any thoughts?
SanDisk Guru
Re: Using the stick with a projector
does the stick work normally with a computer? if so it seems the projector may not be compatible with it.
