Newbie
Accepted Solution
Usable as MP3 storage for an Android Mobile Phone?
Hi all,
is it possible to use the Connect wireless stick to store my MP3s and play them back from an Android 6 Mobile Phone with a standard Music Player app? I couldn't make the sticks content visible from the standard file browser yet. Is the any way to 'mount' it or make it otherwise accessible outside the Connect Drive app?
Thanks in advance for any hint.
Mat
SanDisk Guru
Re: Usable as MP3 storage for an Android Mobile Phone?
I think you would need to use the connect drive app to play the music.
Newbie
Yes, thats the obvious solution, but I was hoping for a full integration into the file system.
