Administrator
Newbie
Re: SanDisk Wireless Stick Support Informaiton page
Sir
I am having android 4.0 tablet.
Through wifi both devices are connecting , but I couldnot see the files in tablet.
Sandisk connect app couldnot loaded in the tablet, since it supports 4.2 and upwards only.
Any solution to use sandisk connect wireless with tablet with android 4.0 version
Laks
SanDisk Guru
can you upgrade the tablet to 4.2?
Newbie
You should be able to access it through your web browser. In the instruction booklet or even the documents here on SanDisk's site should give you the generic web address for your device.
Newbie
Transfer files between Wireless Stick and a device using a web browser
You can transfer files between Wireless Stick and any device with a web browser. This could be useful when a mobile app is not available for a specific platform or it is not possible to install the mobile app on shared devices. For computers this will allow multiple devices to connect wirelessly via a browser instead of a direct USB connection.
Not all features available in the mobile app are available via the web browser. Drag and drop file upload is supported in browsers that support drag and drop.
1 Connect to Wireless Stick Wi-Fi network “SanDisk Connect ######” a. ######willbeauniqueidentifierforyourspecificunit.
2 Enter www.sandisk.com/myconnect in your web browser
3 You can now browse & download files within the browser
Some browsers will automatically try to connect via HTTPS. If you see an HTTPS error, please connect via HTTP.
