Newbie
No more Power at all
Hi Forum,
I realy need your help. By using the stick from one second to the other I couldnt connect anymore. The stick has no power even if I charge it. I cant see any LED at all. so to me it looks like it is not working anymore!? Also the Power button dosent bing any reaktion. Can someone help me please find a solution? Thank you so much
SanDisk Guru
Re: No more Power at all
You can try a hardware reset on the wireless stick. instructions linked below. If that does nto work and it will not charge it may be bad and would need to be replaced.
https://kb.sandisk.com/app/answers/detail/a_id/17549/
