Newbie
Re: Connect from PC to wireless stick
Also check your computer is not set with a fixed IP! That was my problem.
Newbie
To access the USB from PC over Wi-Fi:
1. Make sure that your USB Flash drive is connected to your local/home Wi-Fi network.
2. Get your USB Flash drive current IP address (either from your router DHCP client list or using USB mobile app, about tab)
3. Enter in your web browser in the address bar http://X.X.X.X/files, where X.X.X.X is your flash drive IP.
4. Browser will require a username and password (Trick is here) Username is defualt by SanDisk (owner) while password is your flash drive Wi-Fi password, IF you set a Wi-Fi password to your USB Flash drive then the password to http will be your Wi-Fi password, If you did not set a Wi-Fi password leave it blank.
Thats it! Cheers, Enjoy...
Note: Files access is limited via HTTP only, You cannot add the device to be accessed wirelessly through windows explorer as a network or mapped network drive.
