Newbie
Can't charge from USB wall charger, battery or car USB port.
I don't appear to be able to charge my stick from USB charger - it only charges when connect to my Mac. I've tried various wall charges for smartphone, portable battery that charges a phone as well as a USB charger in my car - all won't charge the device.
Seems stange ??? I have the latest version of firmeware etc just bought the device - Aug 2018.
SanDisk Guru
Re: Can't charge from USB wall charger, battery or car USB port.
I charge my wireless stick using a normal iphone charger and it charges no problem.
With the stick turned off plug it into a USB AC charger. Does the LED turn on? if so what color is it?
Newbie
Strange as it appears to work now. It seems that when the battery was almost depleted it won't charge, only on my Mac. It just flashed orange or somthing and turned off. Strange. It now charges OK solid amber light.
Perhaps it was buy?
