Newbie
Battery replacement
Is there a way to replace the battery on the stick? Mine won't charge on the computer or if plugged into a wall charger.
Thanks!
SanDisk Guru
Re: Battery replacement
no the battery cannot be changed. Contact sandisk support and see if it is still under warranty.
