Newbie
Stream subtitles via WMD?
Hi all, sorry if this is a re-post.
I'm pretty happy with my WMD, using it as a very basic and limited wireless player with my iPad.
I do, however have an important question - is there any way to stream the subtitles of the movies as well? I'm referring to SRT files, located within the same folder of the video files... am I missing something or is it dependent on the player that I'm using? currently using VLC.
Thanks!
Tomer
SanDisk User
Re: Stream subtitles via WMD?
I don't have any experience with SRT subtitles, but I do know my favorite player for the iPad, nPlayer, says they support them.
Newbie
I have a WFD and looking for the same solution for srt streaming.
What I've got so far is a workaround solution...
I use Oplayer HD for watching movies in my iPad. There you have an option to open a file using URL link.
You can use a browser to open your directory of movies in WMD and then you can obtain the a link to the movie file.
Copy this link and paste it to Oplayer HD on a URL link. Voila!!! you can watch the movie with subtitles working!
Hope this helps..
If you know of other solutions, please let me know,
All best,
Sergio
Newbie
Re: Stream subtitles via WMD? [ Edited ]
Options
‎01-22-2015 05:42 PM - edited ‎01-22-2015 05:44 PM
This app "It's playing", availabe on itunes -> https://itunes.apple.com/br/app/its-playing-pro/id442839861?mt=8
will help on this issue. Ir plays the movie with subtitles pretty nice.
Newbie
@smafra - many thanks for your great advice. Having downloaded It's playing I'm actually able to both steam subtitles as well as browse through the contents of the drive, so I don't even have to use SanDisk's app anymore (it drove me crazy)
Thanks mate!
Tomer
Newbie
Hello everyone (again...),
I now also have an Android based tablet which I'd like to use with the WMD.
Is there any similar android app like "It's Playing" that has native capabilities of supporting the WMD and with subtitles option?
I tried doing some research but I can't find any suitable app. I successfully managed to use ES file explorer to connect to the drive in FTP + BS Player for running the movies, but that's a more time consuming process.
Maybe someone has some experience with that? maybe I'm doing something wrong and I can easily use WMD with one of the top playes and be able to add subtitles as well?
Thanks!
Tomer
SanDisk Guru
there is no similar integrated app like infuse on the android side.
