Newbie
SanDisk Connect WPA2 PSK Character Limitations
What are the charater limitations within the Pre-shared key/passphrase on 3.04 with WPA2 (Internet connection)?
My passphrase gets rejected with "Password Incorrect Re-enter password" message within the Sandisk Connect app - the passphrase contains the following characters #,%,$
If I try a passphase without these characters it works fine - I setup a temporary guest WPA2-passphrase network with a passphrase with only letters and numbers.
SanDisk Guru
Re: SanDisk Connect WPA2 PSK Character Limitations
try it without the %
