Newbie
Reset admin pass
I didn´t reset my admin pass.
i pressed and holded the power button for 10 seconds. bla bla bla but i could not reset the pass
any body help me pls?
tks
SanDisk Guru
Re: Reset admin pass
it takes 25 seconds. see below
http://kb.sandisk.com/app/answers/detail/a_id/8650/
Newbie
OK after going round and round at lart sorted.
I Think its just not clear when you read what you need to do to reset PASSWORD.
So after trying few times and it not working.
1 unplug from computer if coneccted and turn off.
2 turn on holding down power button for about 10 seconds or untill all three leds are flashing,
let go of power button right away.
3 wait till SMD resets its self.
4 power on.
5 From your phone run SMD app, and in your Phone settings join you network for your wireless SMD.
6 From your Media Drive App on your select setting at bottem of page.
7 Go to ADMIN a Password Window pops up type in admin and press return/enter
If all is OK you should now be in admin setting screen
8 On this screen you change the name you want your network to be called,  below that
9 You can change the WI-FI Setting Password IF asked for Password enter/type    no password    press enter/return
You are done
Now just trun on and test
Admin password should be admin
WI-FI Password should be no password
If the above above worked you have reset both your passwords for your SMD 'Sandisk Media Drive'
The above was key by key and it worked for me.
I do hope it helps you reset your drive if you have been having trouble to.
Thanks for reading
Leggoman
Let me know if it help you.
Newbie
Thank you for this information!  I was just about ready to throw this thing in the trash.  SanDisk needs to add your answer to their FAQ's!
