Newbie
sandisk usb wireless adaptor
 hello, I just got the sandisk usb wireless adaptor  cruzer glide 32gb. went to install it in my laptop with windows 10 home.
after i installed the software I accidentlly deleted it along with the files I had, so how do I get this back or start over with it.
 your help would be great.   thank you
SanDisk Guru
Re: sandisk usb wireless adaptor
the cruzer glide is not a wireless usb drive. if you ahve a glide the software on it is not needed to use the product. all it has is a password application. if you want that back you can get it from the link below.
https://kb.sandisk.com/app/answers/detail/a_id/2399/
