format for ipad
Help please! I have a sandisk connect that I want to wirelessly stream videos to my iapd mini2. Files are >6GB but I cannot find the connect format t o use. Tried NTSFC and exFAT but neither work. Any ideas please?
if you have a 32 or 16GB WFD exFAT is not supported so you will not be able to add files larger than 4GB. you would need to convert the videos and reduce the size.
the 64GB WFD supports exFAT so if files larger than 4GB are a must you may want to look into getting the 64GB version.
