Wifi Problem on SanDIsk Connect WFD
I m not able to get wifi turned on the flash disk. Everything else is working fine. it is getting connected to my mac via usb. I tried updating the firmware too. But wifi is still not working, there is no blue light showing which indicates wifi is turned on. Even i m nt able to reset it. Can you guys please help me out ?
if you have followed the instructions for turning the WFD on and it is not working it will probably need to be replaced. You can request a replacement from SanDisk Support at the link below.
http://kb.sandisk.com/app/rmaform
