Newbie
Accepted Solution
WebDAV??
Hi, can I configure my wfd for WebDAV?. If Yes, what is my user name And if The password is The same as my wfd?
VIP
Re: WebDAV??
Hi Armejia,
Typically, all you'd need to type in is Server URL (leaving Username and Password empty).
Use www.sandisk.com/wfd  as the server URL and it should work.
If it doesn't work for you - please come back and advise which app you are trying to access the drive from.
Newbie
Re: WebDAV??
Tks, Works without internet share. Only direct.
Newbie
Re: WebDAV??
This is a very old thread, but to connect via WEBDAV the username is:
owner
The password is whatever you use on the SanDisk Connect.
Newbie
Re: WebDAV??
I just registered in forum to be able to thank haluska .Your suggestion soloved my WebDav problem. why Sandisk doesn't say this to everybody? a user should definitely know that th user name is owner .
I have one more question : Does Sandisk Connect Media Stick provide Bonjour service and does it has a bonjour name?
Thanks in advance.
