Newbie
Usage of Wireless Flash Drive as Flash drive and WiFi at same time
Hey,
I want to use wireless flash drive to send/receive files while it was plugged into a computer but the wifi turns off when it is being used as flash drive.
Is there any settings available by which I can use Flash drive and WIFI at same time?
Or Is there any other products available for above usage?
Thanks
Newbie
Re: Usage of Wireless Flash Drive as Flash drive and WiFi at same time
When the SanDisk Wireless Flash Drive is connected to the USB port of the computer it works as a MSC device (flash drive) and the wireless feature cannot be used. Also, there are no other Wireless devices by SanDisk that supports wireless feature when the device is connected to the USB port. However, you can use the wireless feature of the Wireless devices when it is being charged if it is connected to a USB AC adapter.
