Newbie
No audio in videos *.avi with size higher than 1,8gb
Hi
I can't listen avi videos with more than 1.8gb, why???
Thanks
SanDisk Guru
Re: No audio in videos *.avi with size higher than 1,8gb
Do the videos contain a dolby audio codec? If so it looks like dolby audio codec support was removed.
http://kb.sandisk.com/app/answers/detail/a_id/18851/
Some movie files do not playback and I get an error or I do not hear audio
The (iXpand and Connect) apps do not currently support certain audio / video formats, such as those encoded with AC-3 (Dolby Digital) codecs. In some instances, you may be able to select the file and use the “Open in” feature to use other apps on your device that support such formats to playback these audio / video files.
SanDisk values the opinions and concerns of our users. We would like to invite you to take a short survey regarding video playback issues.
Take the Survey Now
