Need firmware help
I bought a cloudspeed SSD that was pulled from a server, but the model number doesn't quite match the models listed under the firmwares, so I wanted to check before trying to flash the latest version. The model number is SDLF1CRR-019T-1HAZ and it is a 1.92 TB SSD. The models listed under the firmware end in either 1HA1 or 1HA2. Also, according to SandiskGuard, the firmware loaded on it is Z30LRPA1, which appears to be quite old. Is it safe to flash ZR08 firmware to this drive? Thanks.
