Newbie
Accepted Solution
Random problem in playlists
I have a mac, I use Mp3Tag to create playlist, then edit in Textedit. Thank you to the person who wrote how to do this here.
Anyway, sometimes it works fine, then I edit a bit and strange things happen. I have tried to put Textedit in unicode 8 -mode, it is in rtf- mode etc
Example:
This playlist were the songs are repeated twice, only plays five of the songs, the last song is not shown;
#EXTM3U
#EXTINF:238,Boni Pueri - Come with me
Music\Kill me heal me chicago\Boni Pueri - Come With Me Chicago Typewriter OST Part 5.mp3
#EXTINF:204,Jang Jae In - Auditory hallucination
Music\Kill me heal me chicago\Kill me heal me OST Auditory hallucination - Jang Jae In ft Nashow.mp3
#EXTINF:211,Boni Pueri - Time walk
Music\Kill me heal me chicago\Boni Pueri - Time Walk Chicago Typewriter OST Part 5.mp3
Another playlist: The playlist works fine when I leave the songs as they are, it works fine when I move around a few songs, it works fine when I delete a few songs and put one on repeat, then I delete even more songs and move them around a bit more and suddenly it doesn´t work, it shows only one of the songs , twice, and it is not the song I wanted to repeat. And I wanted three times repeat.
Is there some hidden code in textedit?
SanDisk Professor
Re: Random problem in playlists
Over the past several months I have been using a simple batch file to create m3u playlists for music subfolders in the main Music folder on my Clip Sport and in my micro SD.  Here is one of the messages I posted on the SanDisk Forum.
     http://forums.sandisk.com/t5/SanDisk-Clip-Sport/Simple-Batch-File-for-Playlist-of-Genre-Folders/m-p/...
This batch file method will also work on a Mac using Wine -> File Manager command.
           ( I could describe this easy method if anyone is interested.)
I thought it might be helpful for you if I attempted to convert your example text from your m3u file into the format created by the simple batch file.   I am using the drive letter F that is used on my Mac for my Clip Sport.  You can see this m3u format is really simple.
    DriveLetter:\Music\Subfolder\Filename         (This method will work with mutliple layers of subfolders)
F:\Music\Kill me heal me chicago\Boni Pueri - Come With Me Chicago Typewriter OST Part 5.mp3
F:\Music\Kill me heal me chicago\Kill me heal me OST Auditory hallucination - Jang Jae In ft Nashow.mp3
F:\Music\Kill me heal me chicago\Boni Pueri - Time Walk Chicago Typewriter OST Part 5.mp3
Please write back and share your results.
Newbie
Sorry I can´t understand your explanation. Thank you for all the work you put in with explaining to people like me what to do. I felt so proud when I downloaded Mp3Tag and edited the playlist in Textedit LOL, but this I can´t understand
It should still be just one textedit-file?
Why add the directory when it is directly on the clip/microcard? Should it not be the relative path? On my computer it says both J and D of some reason, and I tried both instead of F, and none works.
Why not just save the file right away with an  *.m3u ending?
Should it be front slash or back slash?
I have now one document that looks like this:
dir /o:n /s /b *.mp3 *.wma *.wav> Kill me heal me chicago.m3u
Full name of document Kill me heal me chicago.m3u
It is placed directly in the folder named Music. I can see that there is a playlist when I look at playlist from card.mode, but it comes up as empty. I tried with the D: in from of Music for every line, and with J: in front of music for every line , and with only Music first in every line. All the music for this playlist is in that subfolder named Kill me heal me chicago
SanDisk Professor
Hopefully this little exercise is beneficial for both of us. You just taught me the drive letter is not relevant.
Edit your text file "Kill me heal me chicago.m3u" and delete the entire first line.
Then re-save as a text file (ends with .m3u).
This m3u file can be saved in the Music folder OR the "Kill me heal me chicago" subfolder.
If this works OK for you, we could discuss the batch file process and how to execute using the Wine.app on a Mac.
If you have mp3tag working on your Mac, then you likely already have Wine installed.
Alternately, you could use the Textedit.app and revise your future m3u files (from mp3tag) using the simple style shown here.
Please write back with your results.
Newbie
Just a bit busy right now, I will tell you how it went, maybe in the end of this week
Newbie
Hi again.
I am still messing around with this, and it still doesn´t work properly. I tried lots of different ways, maybe one hour every day for a month. Honestly it makes me a bit depressed. I keep trying, because I keep thinkin that Now! This is how it will work!
I did use the style you suggested, but I ran into the same problem.
I tried various ways to copy it into a zoho document, edit it there, and then put it back, and it turns up as empty.
I tried again in the #et -way : I made a playlist from all the songs in the folder and moved it to the playlistfolder, without changing the D:/ just keeping it. It worked fine.
I moved one song from almost last to the front. Suddenly I could see only twelve songs when I looked at it directly from the player, the song I had moved disappeared.
I started over and moved that song by using the "glue in and adjust style"-function (don´t know word in English) . It worked!
I became overly confident and edited the whole playlist like that. Again it turns up empty when I look at it in the player.
I took care to check if it is in text -mode, and as long as it says "convert to rich text" that means it really is in "simple text mode", right?
This makes me crazy!
Thank you for your help and patience.
SanDisk Professor
[ Edited ]
I am really sorry you are having so much trouble with playlists. Especially since you are making a serious effort.
 I have a few simple suggestions for you to try.
1.Try using a very simple text editor app on your Mac. Save the file as .m3u.  Save the file as a simple text file; not rich text.
2. Try creating a simple m3u file based on 3 audio files saved in a new Subfolder under the main Music folder.
    Save this new text file in the new Subfolder with the filename:   Simple.m3u
       Music\Subfolder\audio file1.mp3
       Music\Subfolder\audio file2.mp3
       Music\Subfolder\audio file3.mp3
3. I hope you are able to create this simple m3u file and it works in your Clip Sport.
4. The best way to create and enjoy playlists on a Clip Sport is with a software method. My current favorite method  is to use a batch command.
5. When you want to introduce special repeat and play patterns, this is a bigger challenge.
Newbie
The strange thing is that I have made playlists with repeat and they work just fine. But sometimes it doesn´t work. And I just can´t figure out what is the difference between the one that works and the one that doesn´t work.
And also very strange that there is one playlist like that and it works fine, but now I am finished listening to it (language classes), and want to delete it, but I can´t find it anywhere when I look through with Finder.
The whole thing is very mysterious :-P
SanDisk Professor
[ Edited ]
When you want to use Finder to delete a specific m3u file, maybe try searching the entire directory of the player. Maybe you saved the file outside of  the Music folder?
Also, whenever you "delete" a file from your player, make sure you also empty the Trash on your Mac.  (The file will be marked as deleted but not actually erased until you empty the trash.)
Best Wishes
Newbie
Copy from other message, where RegW gave me the tip on how to do it. The coding of the lineshift on the Mac is not the same as the lineshift that the Clip Sport uses.
Thank you both RegW and
OK I only made one (1) succesful playlist so far, but it is a version I have tried to make thousand times.
So here is how I did it:
I use the program MP3Tag that I downloaded for free to make a playlist in m3u format. The playlist is placed in the folder where the music is. I go to Finder and move it to the folder "playlist"
I open it with Textedit. I take care that it is "not rich text", there are several places in Textedit where you command this, and you have to take care when you save.
Now here is what I did that your comment showed me: Instead of copying one and one line and move it, I copied the line from after the hashtag to the hashtag on the next line, so that the coding of lineshift that the MP3Tag-program made will still be there.
Example:
The playlist looks like this, with the files directly from MP3Tag, but I want to play the Jordan song twice.
#EXTM3U
#EXTINF:177,Kristin Asbjornsen - Some day I ll carry you home
Music\kristin asbjornsen\carry you home.mp3
#EXTINF:238,Kristin Asbjornsen - Im gonna cross the river of Jordan
Music\kristin asbjornsen\river of Jordan.mp3
#EXTINF:152,Kristin Asbjornsen - In the kitchen
Music\kristin asbjornsen\In The Kitchen.mp3
I copy these lines:
Then I put them after the hashtag for the kitchen-song, so the whole playlist is like this:
#EXTM3U
Now I will start a subscription to iTunes to figure out which songs to buy. Finally!
