Newbie
luetooth issue
I am having a problem connecting my powerbeats 3 wireless headsets to the Sandisk MP3 sport clip +
SanDisk Guru
Re: luetooth issue
the clip sport plus currently has a compatibility issue with power beats 3 and airpods. You will not be able to connect using either of those headphones. I would recommend using a different set of headphones.
Newbie
Re: luetooth issue
are there any updates coming to resolve this ?
i need to know if i should take the player back to the store, or keep it around for a patch/firmware updates...
SanDisk Guru
Re: luetooth issue
i would suggest contacting sandisk support and see if they have any update.
Newbie
Re: luetooth issue
they actually realesed version 2.12 to the firmware update for it a few weeks ago.
the issue is that it's still didn't resolve the problem.
keeping my fingers crossed for the next update to do so...
