Newbie
Accepted Solution
Variable speed audiobook playback gone?
The Clip Sport Plus user manual says (on p. 29) that variable speed playback is available for Audiobooks on the Options page.
All I see is "Play via Bluetooth" and "Delete Audiobook." What am I missing? Or has this feature been removed (I'm using version 2.13.B).
I see other posts wishing for variable-speed podcast playback, but everyone seems to assume that it's still available for Audiobooks. Where?
If it's been superceded, can I downgrade to an earlier version (and where would the old firmware files be?)? I don't care about Bluetooth (much), but I care a lot about the variable-speed playback that SanDisk advertised (and still does) with this device.
Administrator
Re: Variable speed audiobook playback gone?
The Clip Sport Plus has never had the variable playback speed option. This is a misprint in the UM. I have reported the issue to the product team and an updated UM should be available in the near future.
Newbie
Oh. Thanks.
Wish I had known that before I bought one...
Newbie
I agree!  I never would have bought mine had I known this however the guy in the store looking up specs said it would play at double speed.  Feels like false advertising.
Newbie
Good day to you,
has the playback speed-up firmware update been released?
My Sandisk sansa clip+ has this function and I like it. I will not switch to a new player unless I am certain to have the same option.
warm regards - Wim
SanDisk Guru
the clip sport plus does not have variable playback speed.
