Newbie
Clip Sport Plus Weird Noise On Shuffle
I am on my 2nd Sport Plus and when I try to listen to music on shuffle I get a very weird sound.
All I get is dah dah dah, dah dah dah, over and over not matter which song I move onto.
It came with 2.0.2 firmware and I have upgraded to 2.0.9
I have ran out of ideas.
Any assisteance would be greatly appreceiated.
SanDisk Guru
Re: Clip Sport Plus Weird Noise On Shuffle
[ Edited ]
What format are the files?
Do they play ok on your computer or any other device?
Do they play ok without Shuffle engaged?
Are you using wired or BT head/earphones?
Newbie
Most are MP3 but some are wma but it doesn't matter as it makes the sound on both types of files.
Yes I can play them fine on my computer.
It will play a song than the next one is just makes a dala dala dala wierd skipping sound.
This is the 2nd one that has done this.
I have a older sandisk sport plus that works fine but the newer ones  are having issues
SanDisk Guru
That definitely qualifies as "weird". Smiley Frustrated
Newbie
Here is what the issue is from what I can tell.
If I copy the files from my old sandisk directly to the new one.. Works perfect..
If I copy it to the windows desktop than to new sandisk it somehow gets corrupted.
SanDisk Guru
Again . . . weird. Sorry, I don't have a reason or solution for you.
