Newbie
Bluetooth doesn't work with Gummi wireless earbuds
I tried connecting my Gummi wireless earbuds with bluetooth on the device and it doesn't connect. All it does is say its searching then after a few mintues go back to music. I have tested the earbuds with other devices and it works fine.
An answer or support would be much appreciated.
SanDisk Guru
Re: Bluetooth doesn't work with Gummi wireless earbuds
check if you have the latest FW and if not update that. Also have you tried any other BT headphones? Do any other headphones work?
Newbie
Thank you a lot for replying.
I have the latest version and i do not have any other bluetooth headphones to test. :/
