Newbie
pls ans me
pls send answer wht do ... my sandisk pen drive problem
SanDisk Professor
Re: pls ans me
You can post your issue here so we can discuss it or you can directly contact the support of sandisk to get a solution to your issue.
you can contact them from here: http://www.sandisk.com/about-sandisk/contact-us/
Good Luck
#Missing the keyboard? Press F1 for help#
SanDisk Guru
Re: pls ans me
deponia - Please note this post is 5 months old. Really no need or help to respond after this long.
And frankly, the reason no one responded before this is most likely because the OP did not give any details about their issue.
SanDisk Professor
Re: pls ans me
Ok thx for the info and advice i will try to keep that in mind for the future posts.
Good Luck
