(anon)
N/A
0
i've problems with ma 2GB flash memory SDCZ6
ma flash is new
i used it only once on ma own PC as a test....and now in its 2nd day it's readed 0 capacity not 2GB capacity
i can't copy anything to it i can't find anything on it its empty
if anyone know a solution for this problem .....please help me
(anon)
N/A
0
Re: i've problems with ma 2GB flash memory SDCZ6
Does your Cruzer have U3 installed on it?  Have you looked at the device with Disk Management?
(anon)
N/A
0
Did you enabled the security on the U3?
try launching first the U3 and then enter your password to unlock the removable drive.
