SanDisk Cruzer Micro 8GB LED Problem?
G'day guys,
Quick question: can anyone inform me if the LED on the above flash drive is supposed to blink when data is being written to it?
Cheers,
Dash
Re: SanDisk Cruzer Micro 8GB LED Problem?
yes the light should blink when data is being transferred. sandisk uses several different controllers in their flash drives. all have different led behavior. how does the led behave on your device?
It's just a steady colour, doesn't blink when data is being transferred. I'm not sure this is normal behaviour for this, but I may be wrong. It's the black SanDisk Cruzer Micro 8GB (black) model. Do you have the same model, and if so does it blink when transferring data?
Cheers,
Dash
the light should blink randomly when data is transfered. how large are the files you are transfering? if you are transfering small files like word documents the transfer will be very fast and you may not see the light blink.
Hi drlucky,
Thanks for the advice. Think I'm going to get myself a new one then as files are of decent size.
Thanks,
Dash
